Reply
Highlighted
can't logon to satellites (RBR50)
I can't logon to the satellites to upgrade FW. It is not reconginzing the login credentials (which I assume should be same as router).  Now I am stuck - updated router to v2 but satellites stuck with V1.12.0.4.
Message 1 of 5
Accepted Solutions
Highlighted
Re: can't logon to satellites (RBR50)
resetting now.  hopefully does the trick.
Message 3 of 5
All Replies
Highlighted
Apprentice
Have you tried the default login?
login: admin
password: password
otherwise reset router and the default should work then
Message 2 of 5
Highlighted
Message 3 of 5
Highlighted
thank you.  Now I just need to figure out how to get the latest FW (img file) for satellites as file from dropbox won't upload.
Message 4 of 5
Highlighted
Apprentice
Make sure you are getting the right file for the right model number.. if it is for Satellite it ends in S.. example RBS50 or RBS40.
Otherwise contact support or let a MOD know to get the correct file like @AmitR or @DarrenM
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1248 views
  • 1 kudo
  • 2 in conversation
Announcements
