Orbi WiFi 7 RBE973
Reply
daisy chain still not working
dgellen
I have the "daisy chain" functionality on my Orbi router/satellite system fully enabled and I also have my second satellite very close to my first satellite (and NOT close to the router) and yet the "daisy chain" functionality if still not working.  The second satellite is still connecting to the router even though it's much farther away and the connection is weak.  Is there anything else to try?  Very frustrating.  Thank you.
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 5
Guru
Re: daisy chain still not working
After enabling Daisy Chain on the router and rebooting it, turn OFF the satellites, then turn back on the closest satellite and wait for it to connect and turn on BLUE? Then turn on the 2nd satellite and wait for it to turn on BLUE?
Message 2 of 5
dgellen
ok, will try that
Message 3 of 5
Guru
Let us know...
Message 4 of 5
Blanca_O
NETGEAR Moderator
Hi @dgellen
We’d greatly appreciate hearing your feedback letting us know if the information FURRYe38 provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1181 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
