Pedrodk's avatar
Pedrodk
Follower
Jul 04, 2021
defaut connexion box SFR TV ethernet or wifi
I have an ORBI RBK50 WIFI network (Router + 1 satellite) The router is connected to a BOX Plus (NB6) from SFR I want to connect an SFR TV decoder to the satellite furthest from the router (WIFI works perfectly). Currently, I have  no connexion  ... for lack of synchronization (the SFR BOX does not seem to have BRIDGE mode, according to the SFR technician). Is there nevertheless a possibility of synchronization so that the decoder works normally? Thank you in advance for advice on how to configure the router.
1 Reply
  • FURRYe38's avatar
    Possible the TV decoder needs to be directly connected to the main unit. Something to ask the ISP service support group about. Something that may not be supported thru Orbi wifi.
