Reply
Highlighted
Apprentice
device not connecting to closest satellite
It looks like many have a similar problem.  I have an RBR50 along with 2 satellites.  My router is on my main floor with 1 satellite upstairs and 1 satellite in the basement.  In my master bedroom, I have the upstairs satellite and about 5 feet from it is my Roku TV.  This TV is connecting to the router down on the main floor.  I've recycled the power on the TV; I've even done a "flush network" on the roku system but it still gets assigned x.37 and connects to the router that is over 70 feet away and through drywall/housing.
I continue to get buffering issues on this Roku TV (mostly Netflix, but some times Amazon Prime).  My internet averages 200Mbps download and my TV on my main floor doesn't have this issue.
Many devices do not seem to connect to the closest satellite and as a result I still have issues and am no better than the Nighthawk unit I had.  I HOPE that forcing the bedroom Roku to connect to the satellite right next to it would resolve this issue --- otherwise, it seems Netgear isn't the answer.
Any suggestions?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 17
Highlighted
Guru
Re: device not connecting to closest satellite
Try turning down the power of the RBR from 100% to say 50%. Under Advanced Tab/Advanced Settings/Wireless Settings. Then reboot the ROKU device. See if it connects to an RBS.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 17
Highlighted
Apprentice
Thank you for the quick response.
Let's see:
router (and satellite) firmware: V2.3.5.30
modem is Motorola SB6141
Size of house: with finished basement ~5000 sq ft
Distance between router and satellites: hard to determine straight line length, with material, but the general layout is the line would be:
Router-->Satellite-->Roku-TV  The Satellite is in between the Router and Roku-TV.  If I had to guess, the satellite(s) and router are within 30 ft of each other.  I'll try the reduction in power of the router, but that would seem to "hurt" the items on the main floor from having good signal/access.
Before I do think, I'd need to understand what it is I'm doing so as to not compromise other device connectivity.
I don't think daisey chain is appropriate since my downstairs satellite is not in line with the upstairs satellite.  I do have "Armor" set; I don't know what "circle", "fast roaming", and the other things are.
Message 3 of 17
Highlighted
Guru
Try setting the output radios of the RBR first. Try 75%. A slight reduction in single coverage, however shouldn't impact anything.
Message 4 of 17
Highlighted
I am having the same problem with a doorbell camera that connects to the farthest device of 3 (the router Orbi) while in a daisy chain setup.
I cannot locate these advance settings/tabs in the app to try and dial down the strength %. Is there another place to do this?
The closest satellite is within 5 feet of the camera too; and always has poor connectivity.
my firmware is V2.3.5.30
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 5 of 17
Highlighted
Guru
Message 6 of 17
Highlighted
I just dont see the advanced tab anywhere in the Orbi APP. Am i suposed to be looking somewhere else?
thanks!
Message 7 of 17
Highlighted
Guru
Yes, use a PC or laptop and web browser connected to 192.168.1.1 or orbilogin.com
Message 8 of 17
Highlighted
Noticed the exact same issue where devices on the network don't connect to the closest satellite. In addition to that, I see connections moving from the 5GHz band to the 2.4Ghz band back and forth, for no real reason. Yesterday, for no reason, our XBOX connected to the router on the 2.4GHz band and it was lagging like crazy where the night before it was connected to the router on the 5Ghz band and there was no issue.
Lots of weird and completely, at first glance, unjustified behavior of the system. It seems to be totally out of control...
Have a roughly 5,000 sqft house with 3 levels with router on the main level, one satellite upstairs and one in the basement
My router is an RBR850 (AX6000 Tri-band) with 2 satellites
Firmware Version: V3.2.15.25_1.3.15
Distance between router and satellites is wirhin 30 ft although on different levels of the house
Have a cable modem with a 400Mbps dl and 20Mbps ul
With that system and the latest firmware, the additional issue is that all these settings that were suggested to adjust in previous posts, are not available to adjust anymore - There is very little that is adjustable now
Also tried all the power cycling things I could think of on the devices, the router, etc ... nothing seems to have any effect on the system behavior
I also am coming from a NightHawk R8000 and although the mesh system seems appropriate with a large house, I feel like I went backwards, even with the latest Orbi system available. A bit frustrating.
Spent 2 hours last night with a Netgear tech specialist but nothing seemed to have changed the behavior of the ORBI system. The last suggestion was to proceed with a router reset to factory settings but I haven't done it - How would/could that help?
The Orbi system is less than a week old and I installed it from scratch out of the box - why should I have to do a factory reset already?
Is the latest firmware possibly the cause of the problem?
Any help/suggestion will be welcome
Message 9 of 17
Highlighted
Guru
Please post about this in the Orbi AX forum for your model Orbi:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Message 10 of 17
Highlighted
No news nor solutions to this problem, now 7months in?! Have people solved this? We wanna know too (a solution), as this buffering problem was THE reason we invested in Orbi mesh. If our device is not connecting to the clisest strongest signal (RBS850),.. but preferring the farthest weakist signal (RBR850).... what are we to do??
Is there a way to configure the system so that ONLY the chosen RBR accepts client connections?
Message 11 of 17
Highlighted
Guru
Thank you.
Message 12 of 17
Highlighted
Initiate
Have there been any news?
Setup:
- RBR50 w/ satelite
- Router and Satelite online
- Satelite ~30 ft from router on the same floor
- Screenshot of Advanced Wireless Settings has been attached
I have 25 connected devices and 24/25 are connecting to the router. Really defeats the reason for getting the Orbi system in the first place. About 50% of the devices are closer to the satelite than the router, but still they are not connecting. Tried removing the network from those devices and re-adding them. Did not make a difference.
How can we force devices to connect to the satelite. Clearly this is an issue with the Netgear product, based on the previous post with other people having the exact same issue.
Message 13 of 17
Highlighted
Master
Setup:
- RBR50 w/ satelite
Actually this is an issue with ALL mesh systems. They are going to connect based on the strongest easiest path. Interference plays a big role. It also depends on how far the devices are from the router or satellite, as well as walls, line of sight, etc.
I recently installed a 4th satellite 35 ft away from the router on the same floor. 1 TV upstairs and another TV right next to the router is connecting to this 4th device. They are the only 2 devices that connect to this 4th satellite, but they do, even though the router is closer to both devices.
Try changing WIFI channels, move the satellite to a different location.
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
There's always a logical answer, if you have all the facts!
Message 14 of 17
Highlighted
Tutor
I have the exact same problem. 40 devices in the house typically connecting to the closest unit and system is mostly fast. HOWEVER, there is an exception with one desktop computer that seems to prefer the satellite versus the main unit. The satellite is two floors away on the other side of the house. The main unit is 20 feet away. If I unplug the satellite, the computer will happily connect to main unit with speeds around 100Mbs. If I then replug the satellite, within an hour, the computer will connect to it and I will get 500Kbps at best. And THEN sometimes the connection drops altogether but will not then reconnect to the main. It is terribly frustrating.
Message 15 of 17
Highlighted
Master
I have the same issue from time to time. I go to the device, forget the Wireless networks and re-connect. It always picks the strongest signal and stayus connected until the closest satellite goes offline for some reason.
Message 16 of 17
Highlighted
Tutor
This is the part where NetGear is really sloppy in terms of their service and product.
One- they want to charge for service on basic crap that should be part of buying their expense products.
Second - NetGear needs to be more proactiv in the forum and answer anything not answered within 72 hours. Sloppy, lazy, and cheap.
Now on to the issue. The internet connected devices do not connect to the closest ORBI device. They should create a way to move a device over the the ORBI main router or one of the satellites.
I look forward to a response eventually but afraid this will take some time. NetGear frequently disapppoints on this front.
Message 17 of 17
Top Contributors
Discussion stats
  • 16 replies
  • 7737 views
  • 12 kudos
  • 9 in conversation
Announcements
