Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
difference between connecting 5 ghz wifi on orbi vs ethernet connection to satellite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-10-16
01:35 PM
2017-10-16
01:35 PM
Is there an advantage? Connecting by ethernet to the satellite, does that yield better speed/lower latency than connecting just to the 5gz wifi broadcasted?
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-10-18
10:08 AM
2017-10-18
10:08 AM
Re: difference between connecting 5 ghz wifi on orbi vs ethernet connection to satellite?
There could be a advantage because you are not using another wireless connection speeds could be better.
DarrenM
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-10-18
10:23 AM
2017-10-18
10:23 AM
I get about 100 Mbps more throughput (575 versus 475) wired to the satellite versus connecting to the 5 GHz WiFi. If you can connect with a wire it would be better, because as @DarrenM indicated, you are not using another WiFi connection and that saves RF airtime for other wireless devices.
Message 3 of 3
Announcements
