Orbi WiFi 7 RBE973
Reply
disable 2.4ghz on orbi
yafai1
Tutor
HELLO
latest softwear 2 orbs less than 30 feet apart signal strength good etc.
slight issues with the orbi currently,
1. 2.4ghz is enabled and i want to disable it
2. im finding that devices are not connecting to the closer orbi
3. the setup is confusing
anyhelp will be aprechiated
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 25
Guru
Re: disable 2.4ghz on orbi
Is the Orbi system operating in Router or AP mode?
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. You can disable the 2.4G SSID broadcast here as well. Though it's only recommended to disable this temporarily and not long term.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@yafai1 wrote:
HELLO
Message 2 of 25
yafai1
Tutor
firmwear is V2.3.5.30
thick walls around 2500sq feet
both connect so far to each other blue light etc
what connection etc i have no idea i cant even change them
lots of wifi nearby (around 10 max)
Message 3 of 25
Guru
IF you have wifi neighbors, might try setting some manual channels on 2.4Ghz.
If you disable the 2.4G SSID, let us know if this changes anything.
Having thick wall could be a factor as well. What is the distance between the router and satellite(s)?
Message 4 of 25
yafai1
Tutor
how do i actually disable the ssid? its just one ssid? i dont get it but the speed diffrence is significant
nothing to do with the satellite its simply the fact that i cant disable the 2.4ghz? its one big network that selects weather your on 5ghz or 2.4ghz if im right (correct me if im wrong)...trying to simple make the whole network 5ghz we dont need the 2.4ghz. 2.4ghz is an issue bevcause lets say im downstairs and the phone is connected to the orbi downstairs 5ghz i go upstaris its still connected to the orbi downstairs just on 2.4ghz?
trying to disable 2.4ghz to force the phone to switch from the main orbi downstairs to upstarirs without turning my phone wifi on and off which usually solves this issue.
know how do i disable 2.4ghz please (step by step instructions)
Message 5 of 25
Retired_Member
Not applicable
I understand that this can be done in the settings/advance.....
The firmware you're currently on has some known issues. -
Was your system working well before the last update?
Message 6 of 25
yafai1
Tutor
just bought it 2 hours ago
Message 7 of 25
Retired_Member
Not applicable
OK....you can try to troubleshoot it, but with the firmware you're running, you're best bet is to try and download/install earlier version.  Look for the download section here for your router/sats
Message 8 of 25
Retired_Member
Not applicable
One other item,...when you said..." its just one ssid? i dont get it..."
That's the way a MESH system works.  The Orbi takes both the 2.4 & 5G and combines them into one SSID. When it's working properly, the Orbi decides which device connects where.
Message 9 of 25
Guru
You can disable the 2.4G SSID broadcast by unchecking the "enable 2.4G SSID Broadcast" found under Advanced Tab/Advanced Settings/Wireless Settings.
Message 10 of 25
Retired_Member
Not applicable
NICE.
Message 11 of 25
yafai1
Tutor
This is tiring. If it was that simple as to just flip a switch I would of have done it. But this **bleep** software is not that user friendly there is no such things as 2.4ghz off/on that mythical switch that you lot are speaking about in the advanced bull **bleep** area just ain't there. If it was I would of have found it long ago which would of have meant that I wouldn't need to post in this community.
Do you lot understand? There is no switch located where you lot have been saying it is. I checked online and there used to be one maybe in a diffrent (older) firmware but today it simply ain't there on the latest firmware and before u say downgrade for the love of god I cant it just upgrades itself. This system is flawed...
Message 12 of 25
CrimpOn
Guru
Maybe this is what people are talking about?  (the check mark box beside "Enable SSID Broadcast")
Message 13 of 25
Guru
So you not see:
Advanced Wireless Settings (2.4GHz b/g/n)
Enable SSID Broadcast <check box
Message 14 of 25
yafai1
Tutor
@FURRYe38 wrote:
So you not see:
that does not do anything? i have a device that only connects to 2.4ghz and it still connects to the wifi network? plus both 2.4ghz and 5ghz and under the same name as in i think they are merged?
Message 15 of 25
CrimpOn
Guru
Devices are funny about "Hidden Networks".  I may be mistaken, but what I remember is sometimes the device has to be told to "forget" a network.
Message 16 of 25
Retired_Member
Not applicable
@yafai1 wrote:
HELLO
Did you ever mention WHY you want to disable the 2.4 band?
Perhaps if you did, the fix would be much more evident.
Message 17 of 25
yafai1
Tutor
Well smart arse it's in this thread read the **bleep**ing thing before u turn all smart on us. Tired of the same old dumb replies.
Message 18 of 25
CrimpOn
Guru
To recap: (a) unchecking the "Enable SSID Broadcast" for 2.4G network, (b) clicking "Appply", (c) telling a 2.4G only device to "forget" the Orbi SSID, and (d) restarting the device.... and the device reconnects to the Orbi anyway?
Message 19 of 25
Retired_Member
Not applicable
2. im finding that devices are not connecting to the closer orbi .
 If this is your reason.....it's NOT.  How devices connect is all about how the Orbi and the Mesh system works.  What's wrong with that?  If you're worried about SPEED, you're chasing rabbits.
OBTW....we're all adults here.  You can use civil and respectable language.  Thanks
Message 20 of 25
BoilerPlate
Apprentice
@vaj you should practice what you preach!!!
Message 21 of 25
Retired_Member
Not applicable
@BoilerPlate wrote:
@vajyou should practice what you preach!!!
How so?
Message 22 of 25
PittsSC1
Initiate
Smiley HappyOne might want do disable 2.4 GHz so they simply always use 5 GHz. Smiley Happy  Is not that reason enough?
Message 23 of 25
CrimpOn
Guru
@PittsSC1 wrote:
One might want do disable 2.4 GHz so they simply always use 5 GHz.:  Is not that reason enough?
Of course it's a good reason. Someone might want (a) to be unable to connect any of the "Internet of Things" devices that only support 2.4G, (b) to have their WiFi signal drop out when they wander too far for 5G to penetrate while 2.4G would keep them on-line.  Netgear could have made discussions like this unnecessary if they had simply added a check box, "Turn off radio" for each band. Smiley LOL
Message 24 of 25
Tucsonbroker
Initiate
You can’t disable the 2.4 radio but you could rename the 5G band to something else. Then have your devices forget the 2.4G info and login into the 5G. The instructions are here on the forum, telnet into the router it’s pretty simple to do.
Message 25 of 25
Top Contributors
Discussion stats
  • 24 replies
  • 17917 views
  • 5 kudos
  • 7 in conversation
Announcements
Orbi WiFi 7
