Orbi WiFi 7 RBE973
Reply
disconnects and latency when using orbi
wolfbow
firmware   V2.1.2.18
I am getting 5ms pings to my default gateway, which is 5x what I would expect to observe and random >100 pings to other hosts on the LAN. Kids claim of random lag and disconnects when playing Fortnight.
I have tried multiple configs with no real change in results.
the built in speed test shows >100mb download and >50mb upload to the internet. but the XBOX network stats only show a max of 50mb down and 50 up, but the tests fluctuate wildly in terms of download speed, from anywhere from 15mb - 50mb.
config:
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 10
webminster
Luminary
Re: disconnects and latency when using orbi
There are several complaints on the forum on the ping RTT variances. I've seen it too.  Part of the issue may involve backhaul retransmissions if you're connected to a satellite.   However, I've often seen this when connected wirelessly to the router, and pinging a LAN server, which obviates the backhaul as the cause.
No version of 2.x firmware I've tried (most of them) gets rid of this issue.
As far as your comment, 5ms is 5x more RTT than you expect, I would not honestly say you should expect much less than 3-4ms if you're connected wirelessly, in most-world cases.
Message 2 of 10
wolfbow
I tried connecting to the base and the satellites as a way to isolate the ping lag and I can repro it on both devices.
when I use the xbox to measure network stats and my kids are complaining of network issues, I also see about 1% random packet loss.
what throughput should I be expecting on a satellite device? full bandwidth or something comparable to a repeater? if it acts as a repeater, I would imagine daisy chaining makes this even more acute.
Message 3 of 10
Guru
You can test with Beamforming, MIMO, Daisy Chain and Fast Roaming disabled and see if anything helps. I've disabled all of these and has helped in most configurations.
Currnet versions of FW aren't the greatest and everyone is waiting on the next update.
It's recommended to connect game consoles via ethernet for best gaming performances.
Message 4 of 10
wolfbow
all of them are disabled and ethernet isn't a great option. thanks for the reply.
Message 5 of 10
Guru
Might have to wait for next FW update.
Good Luck.
Message 6 of 10
wolfbow
do we have a sense for the schedule of the next FW update?
Message 7 of 10
Guru
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-issues-update-3-9-18/td-p/1522633/jump-to/first-un...
You can contact NG support and see if there is a beta file availble.
Message 8 of 10
wolfbow
i havent taken the time to register and i dont have my gear in front of me at the moment to register the serial -- do they moderate this message board?
Message 9 of 10
Guru
There are moderators in the forum however to get registarted you have to be with your HW and you you need to phone in to NG support.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 4756 views
  • 6 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
