mthunter's avatar
mthunter
fluctuating speeds and connectivity
a few weeks ago, my routers did an auto update to version 2.7.3.22.  Ever since, my speeds have been all over the place.  780-940+, with sudden drops down into the 200's.  My streaming tv is almost unwatchable at times.  I also think the internet conectivity goes in and out thoughout the day.  Does anyone have an info, or a solutions to this?
Thanks
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
    try a factory reset and setup from scratch been performed since last FW update?
    I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
    Mine has been stable since the update:
    https://community.netgear.com/t5/Orbi/New-RBK50-53-Series-Firmware-Version-2-7-3-22/m-p/2120708/highlight/true#M123596
    Mine was factory reset and setup from scratch...
    • mthunter's avatar
      mthunter
      Thanks!  Will try that when I get some time on Thursday.  Do  you think I would need to factory reset my satellite too?
