Orbi WiFi 7 RBE973
Reply
help
apdetwiler
Follower
help
I have tried everything to get access to my router... I cant ... my verification questions dont seem to be correct even thought I have them written down.  How do I by pass?  and get access I need?  so sad...
Message 1 of 3
CrimpOn
Guru
Re: help
I do not know if the security questions are "case sensitive" (like passwords).  You might try variations.
Otherwise, the "last resort" is the famous "Factory Reset":
https://www.youtube.com/watch?v=cMw4ePACgc4
After this is done:
  • The WiFi SSID/password are reset to the values printed on the product label
  • The web management credentials are "admin" and "password"
  • When you connect to the Orbi web interface, the setup will strongly encourage you to change the password.
After you get set up again, it is probably a good idea to save the "configuration" to your computer so the next time you can take the option, "Don't set up from scratch.  I want to reload a previous configuration."
Good Luck
Message 2 of 3
Guru
Re: help
What NG router are you referring too?
Try a factory reset on the router and walk thru the setup wizard...
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 317 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
