Orbi WiFi 7 RBE973
Reply
i forgot my security question Orbi router RBR50
Abackman
Follower
When i try to login as Adm  the defautl password doesn’t work not my normal password.
So I choose “forgot my password”  it the my security questions doesn’t work
how do I overcome this ?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
Guru
Re: i forgot my security question Orbi router RBR50
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5144 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
