- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
inconsistent connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have an orbi AC2200 rbr20 connected to a cable modem and a7000 network adapter on a win8.1 computer ~ 30 feet away. netgear genie shows 2 or 3 signals with my ssid having 3 or 4 bars. i can connect but the connection comes and goes, sometimes in minutes, sometimes in hours. some times genie says connected to internet and sometimes it says connected to router. is there some kind of log file somewhere that would shed some light on what is happening?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: inconsistent connectivity
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
