Orbi WiFi 7 RBE973
Reply
jhow do I change or add a phone number to my common account?
KrisG55
I need to add my phone number to my commom account,  also to use for two step verification
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 6
Guru
Re: jhow do I change or add a phone number to my common account?
What product are you referring too?
Message 2 of 6
KrisG55
i guess that is it I also have an extender but its just not working like it says nor does any info work for it.  but i am trying to add my phone number to my netgear common account or the app so I can use it for 2 step verificqtion because when I had it there half the number was not visible and I was not recieving texts sent to that number.  so i can only surmise that it was entered wrong or changed some how.  been having alot of trouble with my neighbors getting into my system to sabotage my cameras
Message 3 of 6
Guru
What product are you referring too? Model# is more helpful.
I recommend you open a support ticket here and contact NG support for additional help and information:
https://www.netgear.com/support/#
Thank you
Message 4 of 6
KrisG55
thanks but it is obvious i will not recieve any help all they do is haqve me verify info and transfer me around then drop the call.  i have spent countless hours qttqched to my phone unable to go anywhere or do anything and after all that i still have no soultion.  sorry u couldnt help either.  boiut to take this equipment back i am so fed up
Model: AC2100|Nighthawk AC2100 Smart WiFi Router
Message 5 of 6
Guru
Just FYI, also helps to post in correct forum for your model router if thats the model your referring to.
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 614 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
