- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
lower signal strength after update to V1.3.0.12
- Mark as New
- Bookmark
- Subscribe
- Permalink
After I updated to the V1.3.0.12 firmware, my signal strength has degraded from what I presume is the router. I used to get full bars while on the floor where the router is located (and I'm usually around 15 feet from the the router through a wall - previously that area was full strength). However, downlaod speeds have not been affected. Now I get three and handoff between 2.4 and 5 seems a little more clunky. Any thoughts of causes/solutions? Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: lower signal strength after update to V1.3.0.12
try factiry resetting the orbi system and re do the initial setup as this may fix the issue
pete
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did the factory reset, results pretty much the same. Maybe the next firmware update will fix this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello creaky
We just released 1.3.0.26 try to upgrade to that and see if you are having the same issues.
DarrenM
