Reply
manual switching from 2.4 to 5.0
kilopilot
Follower
My computer automaticly selects 2.4 G and that is so overloaded that I am only getting 10MBPS yet on my other computer using 5.0G I get 300MBPS.  How can I get devices to switch to 5G manually?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
OrbiPhilip
Luminary
Re: manual switching from 2.4 to 5.0
From This Post:
1. Enable Telnet on http://192.168.1.1/debug.htm
2. Open Terminal (or whatever your command line app is) and enter:
telnet 192.168.1.1
3. After you're connected enter the following 3 commands, pressing Return after each one:
config set wla_ssid="Whatever You Want to Call Your 5 GHz Network"
config commit
reboot
4. Disable Telnet on http://192.168.1.1/debug.htm
Message 2 of 4
ekhalil
Master
You can set the computer wifi adapter to prefer 5GHz.
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBK852 AX6000, AP Mode, Wired Backhaul / Orbi RBR50 + 4x RBS50, Router Mode, Wireless Ba ckhaul | Switches Netgear GS208Time Zone CET (Sweden)
Message 3 of 4
ekhalil
Master
It's only the client that can choose which band to connect to in  a single SSID.
In My Windows Computer, in the Wireless Adapter Settings, I have the following:
I did not see similar settings in my MacBook.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2179 views
  • 0 kudos
  • 3 in conversation
Announcements
