Reply
nearby device won't connect to satellite - Do not mix RBR50 & RBS20
Raee
FYI   rbr50   rbs50  &   2 x  rbs20 (rbk43 kit) satellites
No matter what power recycling, hard wired or wifi, etc etc no connection it seems that my iphone could smell the RBR50 and so it would never hook up to the RBS20 satelite.   Neither would my laptops. Finally, since we cannot choose which device connects to what device I had to decide what to do.
After calling tech support I returned the kit to Amazon.
In any case I should of simply bought a dual satelitte kit from the start.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 22
Guru
Re: nearby device won't connect to satellite - Do not mix RBR50 & RBS20
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 22
Raee
Why? The object of the game is maximum coverage in a concrete home, btw latest FW.
Hence the addition of the 2 extra satellites.
Message 3 of 22
Raee
Also we can get 500mbs down and 20 mbs up on wifi on the RBR 50
Message 4 of 22
Guru
Why? "concrete home" this would be your problem. Concrete and steel will impact signal travel and performance. Your devices maybe picking the RBR since they seem to feel the RBR signal is better than the RBS. It's to the wifi devices to pick and choose where they connected too. Orbi doesn't do this.
Message 5 of 22
vajim
Master
Not true
The router is the decision maker
Message 6 of 22
Raee
So what that means is that the system does not work with a MIXED satelite as quoted... This will be my last post
Message 7 of 22
Raee
Hi Raee,
vajim (Virtuoso) posted a new reply in or on 2021-01-28 03:49 PM :
Not true
I am afraid your above statement is incorrect .   The user cannot choose which device attaches to which satelite.
Message 8 of 22
Guru
You can try Voxels FW for Orbi if you think it will be helpful:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883...
Good Luck.
Message 9 of 22
DeanB1452
Apprentice
I have one RBR50, two RBS50's and one RBS20.  One of the RBS50's is wireless and the other RBS50 and RBS20 are hard wired.  I haven't had any problems with devices moving from one satellite to the other.  Once in a while, a device will be connected to the router (furthest away) but eventually it moves back to the closest one which was the RBS20.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 10 of 22
Raee
Good for you but on my end it would never switch over, maybe another RBS50 would solve it I might try it but for now a hardwire connection might be a good solution.
Message 11 of 22
vajim
Master
@Raee wrote:
Hi Raee,
Not true
that's NOT what I said.  The ROUTER decides.
Message 12 of 22
Guru
Further proof that devices pick and choose where they connect too. The router/ RBS only provides the platform and signal to connect too. Fast Roaming helps devices move from one signal to another, based on if they also support fast FR. Then the device will freely pick and choose a better signal. If they don't support FR, then users have to force them by disabling the wifi radio on the devcie for a few seconds then back on, then the device will find the closer signal and connect to it.
Message 13 of 22
vajim
Master
you keep bringing this up.  Why?  To poke me in the eye
still trying to understand what difference it makes?
using the arguement above, at the start it's the user who decides where the device is located at the time of connection?  Under that thought it would be the user who decides.  So there ya go....another option and answer to this useless question
Message 14 of 22
DeanB1452
Apprentice
I live in a 1600 sq. ft., 3 bedroom, wood framed, single story house.  Each satellite is about 30 feet from the router in each corner room of the house.  Implicit Beamforming, MU-MIMO, and Fast Roaming are enabled.
Message 15 of 22
vajim
Master
you may want to uncheck Fast Roaming
Message 16 of 22
Guru
For that size of home, if you have the RBR and 2 or 3 RBS, that maybe having too much wifi signals. For 1600 sq ft 1 RBR and 1 RBS would be only needed. I have a 5000sq ft phone and use only 1 RBR and 1 RBS most of the time and coverage is good all around.
Message 17 of 22
vajim
Master
copy paste not working?
 5000sq ft phone.....that's a big phone
but we got ya...you meant to say 5000sq ft home...or my home is 32% bigger than yours
Message 18 of 22
Raee
My issue is now solved, NETGEAR's Tech support recommended to return the kit, the matter is closed and the RBK43 has been returned.
Message 19 of 22
vajim
Master
sorry to hear that.  Let us know what you end up with.
Take care
Message 20 of 22
DeanB1452
Apprentice
Originally I had just the RBK53 and some of the Ring cameras around the perimiter of the house had weak signals.  Added the RBR20 to the master bedroom to boost the signal to the Ring Camera in one corner of the backyard and moved one satellite to the other corner of the house to provide a wired connection to a desktop computer in my child's room as well as the rest of the backyard which was having dead zones before I repositioned them.  Basically a router/satellite in each corner of the house to cover my 6200sq ft lot.  Haven't had any issues with the Ring devices ever since.  Haven't had any issues roaming around the house or backyard streaming music on my iphone with fast roaming enabled too.
Message 21 of 22
vajim
Master
Nice, so check those two options off the list
Message 22 of 22
Top Contributors
Discussion stats
  • 21 replies
  • 542 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
