- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
orbi RBR problems
- Mark as New
- Bookmark
- Subscribe
- Permalink
orbi RBR problems
hello please can you help I have minimal IT skills, ihave a orbi RBR50 and BRs50 satalites when i check the app it says they are all connected and working good, i have 3 satalites all not that far away from eash other so should have supper wifi conisdering the cost but even though it says they are all working fine it seems we are connected to the main router and if we go in any other room even with the satalite in the room we cant get internet.
we only have 1 wifi connection so cant get that wrong
if i disconnect one of them they all go red and when they re sync they are all good they seem like they are all working as they should but just not sending a wifi around the house
any ideas what i need to do
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: orbi RBR problems
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
i dont know what all them letters mean sorry, we have the latest firmware i do know that i will go through you list and try fine all them bits and check them
i have a vodafone router
some of the settings in the app
WPA2-PSK [AES]
Hardware Version RBR50 Firmware Version V2.3.5.30 GUI Language Version V1.0.0.360 Operation Mode AP is AP mode right ????
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have a big house but only need internet in part of it they are all 20 to 30 feet from each other
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possibly.
We need to check What is the Manufacturer and model# of the ISP modem the NG router is connected too? Possible this modem has a built in wifi router already. So maybe your RBR is in AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
so my vodaone router all it says is a HHG2500 thats all it says no make 🙂 its what vodafone give you what you switch over i know that dont help i do think its a HUAWEI
that is the router that supplies the wifi
i am not sure what isp and ng is but i think i understand they are to to router next to eat other the RBR50 and the vodafone
i only know its in AP as i see a IT freind change it over and said this will make it work right as we was having probmlems with lots of dialog boxes coming up with questions that we had no way of filling in like a user name and password on normal web pages ??
i must say i have had trouble with these since i got them its been a nightmare and no one will talk to me on phone as these was here when i moved in
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see yes that model has wifi and a router built in. Reason why your Orbi in in AP mode then. This is fine. Seen review that its not a great modem as well.
Need to find out if your IT friend disabled the modems WiFI radios as well. if these radios are also running, then this would be an additional cause of problems with the Orbi wifi running. Make sure the modems wifi radios are fully turned OFF.
You might ask your IT friend to help you with the suggestons I posted for you to try.
