- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
orbi RBR50 satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
if my orbi satellite is with a poor signal (yellow on the network map app), can i plug a ethernet cable from the main orbi directly to the satelitte will fix the signal problem?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: orbi RBR50 satellite
@RIALMADA wrote:if my orbi satellite is with a poor signal (yellow on the network map app), can i plug a ethernet cable from the main orbi directly to the satelitte will fix the signal problem?
If you connect the satellite to the Orbi router you will setup a wired backhaul. The nice thing about it is you can move the satellite further from the Router and get broader WIFI coverage. you can also connect a switch to that satellite and run more cable to various other locations. However if you move the satellite too far, you will lose the overlapping WIFI and could have weak signals in between.
One advantage is if you wanted to have WIFI in your garage and it's 60+ feet away. You can connect the Satellite to the Router and have great WIFI in your garage perimeter. My setup is similar as I have a detached building. I ran Network cable to it and have 1 satellite in the office garage building.
- Mark as New
- Bookmark
- Subscribe
- Permalink
thank you very much.
only one more question.
and if in this path, between the router and the satellitte, have two switchs. will be a problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
