Orbi WiFi 7 RBE973
Reply
orbi RBS50 wrong wifi name on bottom sticker
Frank70
when i want to install the Orbi router , it is asking to connect through wifi of the Orbi rbs50 ,
the wifi and password is mentioned on the bottom of the device ,
BUT the wifi that is popping up on my laptop isnt the same name , so also the password isnt matching ...
result i cant connect !
pls help
Message 1 of 12
Guru
Re: orbi RBS50 wrong wifi name on bottom sticker
You should have a RBR50 as well. The RBS is the satellite that needs to be connected to the base RBR router first.
Please post here in the Orbi forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Message 2 of 12
Frank70
i could connect fianlly the Router but the sattelites want connect
i ahve reset them , but the power button continues to blink red and i cant connect them at all .
Model: RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 3 of 12
CrimpOn
Guru
@Frank70 wrote:
I could connect finally the Router but the sattelites won't connect
I have reset them , but the power button continues to blink red and I cant connect them at all .
When the power LED blinks red, the satellite may be broken.  Here's what Netgear's web site says about the power LED:
Router and satellite power button LEDs
Solid green. Your Orbi router and satellite are powered on.
Solid amber. Your Orbi router and satellite are rebooting.
Pulsing amber. You must reset your Orbi router and satellite to factory default settings.
Pulsing red. Your Orbi system might need attention. Contact support.
Message 4 of 12
Guru
factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, then press the black sync button on the back of the RBS and RBR. Wait for the top led on the RBS to turn BLUE.
Let us know if you can get to this stage or not.
Message 5 of 12
Frank70
the orbi router ha sthe latest upgrade
but the satellite cant connect in no other way so impossible for me to see which firmware it has
Message 6 of 12
Frank70
1 satelite is now green but doest connect and also i cant reset it anylonger , even after holding reset button for over 20 sec
the second satelite continues to blink red and nothing happens
Message 7 of 12
Guru
You'll need to file a support ticket and get the RBS replaced:
https://www.netgear.com/mynetgear/registration/login.aspx
Message 8 of 12
Frank70
How do i file for a support Ticket ?
i bought the divices online in thailand " Lazada "
Message 9 of 12
Guru
Need to create a user account and profile with the link I provided.
Good Luck.
Message 10 of 12
Frank70
sorry , i doesnt work on how to creat a support ticket
i have 3 sattelites and a router
it should be MUCH easier to exchange this to ones that are working .
Message 11 of 12
Guru
You'll have to contact NG support.
Good Luck.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1779 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
