Reply
orbi and draytek vigor 130 no internet
moelygaer
SO my orbi rbk50 is working fine with a cheap and cheerful dlink modem. THEN I decide to upgrade the modem to a draytek vigor 130 and no internet connection. Good support from draytek established I could get a connection to the internet from my laptop so the problem is with the orbi router, all have been rebooted etc etc any ideas out there?
cheers
chris jones
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
DarrenM
NETGEAR Moderator
Re: orbi and draytek vigor 130 no internet
Have you tried to factory reset the unit by holding the reset button on the Orbi for 10+seconds then you will have to set up the orbi router again.
DarrenM
Message 2 of 3
moelygaer
I tried this, hard reset the orbi with the new modem attached and it worked YAY
thanks for the help
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1117 views
  • 0 kudos
  • 2 in conversation
Announcements
