Orbi WiFi 7 RBE973
Reply
orbi app not connecting via remote management (to two different remote routers)
mrompala
Follower
Today I tried to connect via remote management to two Orbi routers.  I push "connect with remote management", and the two routers are showing up, but when I choose a router I get a screen saying WiFi Not Detected (with two buttons - Try Again and Connect Remotely).  I logged into one of the routers using the ip address in a web browser and everything looked fine.  Before today, I have used the Orbi app extensively and have not had a problem.  App version 2.4.12.5, both Orbis are fw 2.3.5.30
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 8
Accepted Solutions
Christian_R
NETGEAR Employee Retired
Re: orbi app not connecting via remote management (to two different remote routers)
Hello Orbi Community,
Please be advised that we have been made aware of an issue with Remote Management functionality not working when using the Orbi or Nighthawk app. This issue should now be resolved. If you're still experiencing issues please send me or any of the other Community Team members a message.
Thank you,
Christian
Message 8 of 8
All Replies
Guru
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Thank you.
Message 2 of 8
jamienbermy
Tutor
Same issue on remote manegment via ios app
I can't find the thread on the app message baord
Message 3 of 8
Guru
Post a new post if you don't see one.
Message 4 of 8
jamienbermy
Tutor
Message 5 of 8
Kenjimaru
Tutor
Same issue here, cant find thread of the same issue
Message 6 of 8
Guru
You can select on the link and post there or make a new post over on the Orbi app forum.
Good Luck.
Message 7 of 8
Christian_R
Thank you,
Christian
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1865 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
