- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
orbi network turn of by dos attack
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
My orbi system turn off a view time's a week. When I take a look at the log file there is a dos attack standing on that time.
I'm using:
firmware version 2.3.5.30
orbi system RBR50
can someone help me out?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: orbi network turn of by dos attack
My experience (since I began saving Orbi logs on two systems last March) is that the Orbi recognizes dozens of what it characterizes as "DOS Attacks" every day. Already since Jan 1, my Orbi has logged 82. Last fall, there was a period of about a week when the number of attempts was 3-4 times "normal". Yet, my Orbi never goes down. One of the things that annoys users is that when the Orbi "reboots", the log file is erased, and thus does not record "what happened".
So, I have no doubt that you are correct that the Orbi is having a problem several times a week, and it can be a struggle to identify and resolve the problem. The DOS attacks that are recorded are entirely normal and are not likely to be the cause. As an example, my phone gets 20-30 "robocalls" every day. Yet, if my phone service goes down, it is not likely to be the robocalls that caused it.
We generally start by asking:
- What firmware release is on the Orbi now?
(and, no, we are not asking you to "update firmware". sometimes that is the wrong thing to do.) - What brand and model of modem is the Orbi connected to?
- Is there a distinct "pattern" to the service interruption?
(once a day? 2-4 times a day?) - Is there a distinct pattern to how long it is before the Orbi fails from the time you restart it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
the firmware version is V2.3.5.30
the brand of the modem is one of my provider
and there is not something like a pattern to the service interruption.
sometimes it happens twice a day and sometimes it works good for a whole week.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Orbi is "blocking" those attempts already. The only way to keep them from reaching the Orbi is at the ISP, and my experience is that is something they are not set up to do. When my phone says an incomming call is "Listed as a telemarketer", the call has already arrived.
You can instruct the Orbi to stop logging these nuisances. They will still be there, but you will not be told about them. All of the annoying robocalls that come to my phone and do not leave a message appear in my "Missed Calls" list. I choose not to scroll through the list of "missed calls", but those calls still happened.
It is not acceptable when a WiFi router fails often. My Orbi stays up and running for months despite all of these things being logged. If the Orbi is having to be rebooted often, I am very confident (1) there is a problem, and (2) the problem is not these DoS attempts in the log file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did a reinstall last weekend but today there was the same problem as before.
So the problem is still there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
You might update to v2.5.1.8, factory reset and setup from scratch and see if this changes anything.
@Z190mn wrote:I did a reinstall last weekend but today there was the same problem as before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did the factory reset a view weeks ago. after that I did the firmware update to v2.5.1.8.
But there is still the same problem that the orbi system reboot a view times a week. knows someone a fix for this problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have a modem from a dutch provider. And the modem is in bridge mode.
This is an URL to the specifications: https://nl.hardware.info/routers.9/compal-ch7465lg-zg-ziggo-connect-box.371250
There are a view other wifi connections nearby, but if I check this on my phone I count 4. So I don't think that's the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would try this:
Configure the ISP modem back to router mode. Disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried what you just said. This works good for a view days but after that the orbi had the same problem as before.
So I don't think that this is the good solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you changed the WiFi SSID and Pasword on the RBR?
Seems like something is going after the Orbi or there is some interferences.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry for the delay.
I have tried but non of the things are working. 😞
I had taked a look for all the channels what my neighbors but there are a view different channels.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You may want to contact NG support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problems with a simular setup both in router and DHCP mode.
Firmware Version | V2.5.1.8 |
The router resets several times a day, the only logging is a dos attack.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since last FW update? Try this.
Reboot or power cycle all network devices as well after the reset.
Power OFF the ISP modem for 1 minute then back ON and then setup the RBR.
@Spider4 wrote:I have the same problems with a simular setup both in router and DHCP mode.
Firmware Version V2.5.1.8 The router resets several times a day, the only logging is a dos attack.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The netgear orbi router RBR50v2 is connected to Eurodocsis 3.0 modem.
I did factory reset of router and modem, to test the setup in orbi in router and dhcp mode.
The result is both negative.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where are these attacks coming from? Is the IP addresses a external address or an internal address?
Try downloading v30 FW on the RBR to see if this changes anything...
@Spider4 wrote:The netgear orbi router RBR50v2 is connected to Eurodocsis 3.0 modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
example: in DHCP mode
[DOS Attack: RST Scan] from 151.139.242.13, port 443 ......
[DOS Attack: ACK Scan] from 212.123.200.220, port 220 ......
example: in router mode
[DOS Attack: RST Scan] from 17.179.252.32, port 443 ......
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry 2 typo's in the port; port is always 443
[DOS Attack: ACK Scan] from 212.123.200.220, port 443 ......
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might check those IPs with a whois web site.
Ask your ISP to give you a different WAN IP address to see if the attacks stop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have asked for the helpdesk for support and after a clean installation all works again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
