- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
orbi schedule does not work
- Mark as New
- Bookmark
- Subscribe
- Permalink
I setup orbi schedule to turn off from 12:00 am to 6 am. It did turn off but cannot turn on anymore. need to reset to get wifi work.
Any idea?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: orbi schedule does not work
Hello dkpilgrim
What firmware version are you on?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@dkpilgrim wrote:I setup orbi schedule to turn off from 12:00 am to 6 am. It did turn off but cannot turn on anymore. need to reset to get wifi work.
Any idea?
Check that your Orbi has the correct Date/Time. I have found mine not picking up the Date/Time from Netgear NTP servers as I use the Block Services per Schedule. I have even resorted to using Telnet to set the Date/Time manually at times. My Orbi has the correct Date/Time with the latest firmware after a reboot. You can check the Date/Time on your Orbi under Advanced tab - Security --> Schedule. At the bottom will show the Current Time. I just thought that might be your issue...
- Mark as New
- Bookmark
- Subscribe
- Permalink
i tried setting the schedule to block a certain time. Internet is still up.
Then I tried setting it to block all day everyday. Still doesn't work.
Tried blocking all services and all sites according to schedule (everday all day). Also doesn't do as it should. Internet is still up.
Resetting the router doesn't fix the problem. Schedule still shows all blocked at all times, but internet is still up and nothing is blocked.
Why hasn't this bug been fixed? Any help please?
Router Firmware Version
V1.12.0.20
