Orbi WiFi 7 RBE973
Reply
orbi
leffcombs
Follower
orbi
Im using orbi Orbi Rbr50 and is weak tv breaks up and freezes, what extender would work, can I get a extender and connenct to ethernet cable for good reception and add tvs
Message 1 of 3
CrimpOn
Guru
Re: orbi
It will probably help to have more information about the situation:
  • What is the brand/model of modem the Orbi is connected to?
  • What "speed"  is being provided by the ISP?  (Has this been tested?)
  • How are the TV's connected?  (to the router?  to the satellite?  ethernet or WiFi?)
Message 2 of 3
Guru
Re: orbi
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 450 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
