Orbi WiFi 7 RBE973
Reply
ordbi rbr20
yorkytoo
ordbi rbr20
Need help please
My rrouter/moden is on 192.168.0.1 - 192.168.0.254
My orbi is setting itself to the 192.168.1.1 etc
How can I get both units on to 192.168.0.1 etc and not have any conflicts or subnet problems
Any ehlp much appreciated
David
Model: AirCard 306U (all others)|AirCard® USB 306, RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
CrimpOn
Guru
Re: ordbi rbr20
If the Orbi is set to "router", then it will get an address from the modem and will set itself up as the "gateway" between the Orbi network and the outside world.  i.e. It will give out DHCP addresses to all devices connected to the Orbi in the 192.168.1.x network.  This is the way routers work.  HOWEVER, this also means that you have two routers, back to back.  What people call a "double NAT" condition, which is not generally a good thing.
The suggested solutions are:
  1. Put the modem into "bridge" or "passthu" mode so that the Orbi gets a public address from the provider and is the only "router".
  2. Put the Orbi into Access Point (AP) mode, so that the modem/router supplies IP addresses to all devices.
Message 2 of 3
All Replies
CrimpOn
Guru
Re: ordbi rbr20
Message 2 of 3
yorkytoo
Re: ordbi rbr20
thank  you I knew someone would have a solution
Many thanhs again
Regards
David
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 857 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
