Orbi WiFi 7 RBE973
Reply
parental control Schedule device connection
Crg1
Star
I am looking for scheduling control over specific connected devices to allow or disallow internet connection. I don't see that with Orbie or with the Genie or with the parental control page. I previously owned a WRT1900 and that software on Web and Mobile did allow me to control internet access per device in the parental controls - However, I do not see that function in this new Orbie controls either on web or mobile.
Message 1 of 6
DarrenM
Sr. NETGEAR Moderator
Re: parental control Schedule device connection
Hello Crg1
Orbi does not have the function to individually control devices access.
DarrenM
Message 2 of 6
Crg1
Star
Will it come at some time or is there a workaround? My older WRT1900 had it in the web and mobile app.
Message 3 of 6
JGold
Tutor
This feature would be incredibly helpful, and is very common on routers.
Specially, the ability to turn on/off access by device (not IP) based on a schedule.  For example, I would like to automatically turn off access to the gaming console between 10 PM and 9 AM every day, turn off smartphone between 4 PM and 7 PM on weekdays, etc, etc.
Please advise.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 4 of 6
RUDY06
Agreed!
Scheduling is a very big missing component.
Netgear...please advise if this option will be added.
Message 5 of 6
chrisyng
Initiate
You can always utilize the "Block Services" and "schedule" functions under the security tab of your router..
Create a rule to filter out all TCP service for specific IPs under the Block Services section and set it to "Per Schedule" , then go into the "Schedule" tab and set up the time frame you want things to be blocked..
Not quite as simple as some other router's parental controls, however provides the same results
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2855 views
  • 8 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
