Orbi WiFi 7 RBE973
Reply
poor wireless performance on devices connected to orbi router
tadBR
Guide
I am experiencing very bad wifi performance on devices connected to orbi router with instability and wifi speeds below 100mbps (tested with wi-fi sweetspots) in front of the router. Speed when devices are connected to orbi sattelite are far better (300mbps average). I have changed wifi channels but still had the same results.
1.Anyone with the same problem? any idea to solve it?
2. are orbi router radios different from orbi sattelite wifi radios?
my firmware version 1.4.0.18 (last to the date)
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 5
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: poor wireless performance on devices connected to orbi router
Hello tadBR
You may want to try and factory reset the router to make sure it was not a issue with a setting but if that does persist contact support as they can figure out if that is a defect or not in the unit and replace it if needed.
DarrenM
Message 5 of 5
All Replies
DarrenM
Hello tadBR
What is your Internet speed and what type of devices are getting the slow speeds?
DarrenM
Message 2 of 5
tadBR
Guide
My internet speed is 120mbps by cable
My devices are mostly apple devices like iphone 7, airpads, a new macbook 12 and a samsung notebook and a synology nas.
When devices are connected to the sattelite, the have 300mbps average speed. When they are conected i have 10-20 mbps average and a very unstable connection. I can't even get 100mbps when connected to the router.
Message 3 of 5
GaryInEdmond
Guide
I would call their customer support as this is not the typical experience.  I regularly get over Mbps on my desktop computer connected via wifi.
http://www.dslreports.com/speedtest/7377337
In areas that didn't have wifi coverage before the Orbi I get over 100Mbps.
When you call customer support, there is, or at least there was, an option specifically for the Orbi.
Message 4 of 5
DarrenM
Hello tadBR
DarrenM
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4231 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
