Orbi WiFi 7 RBE973
Reply
post V2.5.1.8 install regression
jefftechaz
post installation of firmware V2.5.1.8 lost the capability to edit nvram and set ssid for 5g to another name,  it takes the change but once a reboot occurs sets it back to whatever the 2.4g name is.  has anyone seen this? or no how to resolve?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Retired_Member
Not applicable
Re: post V2.5.1.8 install regression
so why did you install it?  what did you have before?
Message 2 of 5
Guru
NG doesn't support separation of SSIDs so NG maybe stopping this back end use with stock FW going forward. It's up to you though. Keep whats loaded or try useing the system as it's designed with stock FW.
You can also use Voxels 3rd party FW for Orbi.
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1839...
Good Luck.
Message 3 of 5
jefftechaz
that being said, why doesn't the gui give you the ability to have seperate ssid's for the seperate bands? as other routers do.
Message 4 of 5
Retired_Member
Not applicable
Because under a true mesh system they're supposed to be combined.  The fact that some have figured out a way to split them is not suppported by NG and basically defeats the concept of MESH.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 524 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
