Orbi WiFi 7 RBE973
Reply
puter is hiding
PapaNewIrish
puter is hiding
Hi, on my android app my Orbi network is connected and lists my computer as being on the network but whenever I go to Orbilogin website on my computer browser it says "Looks like you're not connected to your Orbi Wifi Network"
Any suggestions would be great, thanks.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
CrimpOn
Guru
Re: puter is hiding
Have you tried connecting to the IP address of the Orbi router, i.e. http://192.168.1.1 (the most usual router IP)
Message 2 of 3
PapaNewIrish
Re: puter is hiding
No, I named the orbi wifi connection and that's what the devices connect to.
When I pull up the android app it shows all the devices connected to the wifi, including my android device and the computer I'm talking about.
I will go see if I can connect to that, thanks.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 358 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
