Orbi WiFi 7 RBE973
Reply
"404 not found" when trying to access adminpages
Retired_Member
Not applicable
Hi
My router suddenly started to show a 404 Not Found when I try to login to adminpages. I asks for username and password and then show 404 Not found. Also tried to access the debug page https://192.168.1.1/debug.htm and I then get a "500 Internal Server Error". Anyone have a clue, as I dont want to factoryreset?
AJ
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 7
Guru
Re: "404 not found" when trying to access adminpages
Does http://192.168.1.1/debug.htm work? Don't use HTTPS.
What browser are you using? Try IE11, FireFox or Opera.
Be sure to clear ALL browser caches, exit the browser then re-launch and navigate to the RBRs web page.
Message 2 of 7
Retired_Member
Not applicable
Firmware: 2.5.1.8
Same problem with http://
Get 500 Internal Server Error
The orbi app also have problem and cannot login anymore. Reboot tried also, but no go
Message 3 of 7
Guru
The RBR is in a bad state, press the reset button in back for 15 seconds then release. Use a wired PC and setup the RBR from scratch.
Message 4 of 7
Guru
Any progress on this?
@Retired_Member wrote:
Firmware: 2.5.1.8
Message 5 of 7
Retired_Member
Not applicable
No progress at the moment, I hope not to lose all my config and do a factory reset. Internet is working as normal but unable to do any changes 🙂
Message 6 of 7
Guru
I know. A reset will be needed. After doing a reset, and you get things set back up again, please do a backup configuration to file. So if next time something happens and a reset is needed again, you can just load everything up from the back up file. Saves time and headache.
Good Luck.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3314 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
