- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
rbk22
- Mark as New
- Bookmark
- Subscribe
- Permalink
rbk22
New to all this tech stuff. On my network map on my Orbi app the internet light is green the orbi light is green the satelite 1 is orange ? does that mean it's not getting the wifi connection . Another think do i have to turn off my homes wifi on the router if so how do i do that i go to the 192.168.1.1 and it won't let me on it's saying my internet is not private . Thanks s
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: rbk22
What is the Manufacturer and model# of the ISP modem the NG router is connected too?
What is the top ring LED look like on the RBR and RBS?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: rbk22
Please do not post serial #'s or MAC addresses in public forums.
By the looks of "Ip 10.0.0.1" would inidcate your ISP modem already has a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I recommend trying option #3...
Whats the top LED on the RBS show if anything?
