Reply
rbk40 vs rbk20
rvilata
rbk40 vs rbk20
Already decided to purchase a kit RBK40+satelite, when I was trying to buy through Amazon I noticed that was a new model called RBK20 (on the amazon appeared as "new model"). Then I search on Netgear website and I found it, but without clear differences.  The only remarcabable difference is, a part of the phisical dimensions and weight , the number of LAN ports and the flash and RAM memory. RBK20 have less LAN ports and less flash and RAM,.........but may be both parameters are linked..... sounds rasonable that a systems with less LAN ports need less RAM.  But I router with only 512Mb RAM sounds not enough....
LAN ports are really not important in my case, but can someone knows if there is other differences more related to performance or speed.
Thanks a lot.
Ricard
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 4
Guru
Re: rbk40 vs rbk20
Key specs to look for are wireless connection rates and over all home coverage sq footageL
RBR40:
Combined WiFi speed2,200 Mbps (400 + 866 + 866Mbps)
Coverage4,000 sq ft
Dedicated Backhaul2x2 (866 Mbps)
WiFi Technology
Tri-band
4GB flash and 512MB RAM
RBR20
Orbi AC2200 Router and AC2200 Satellites (866+866+400Mbps)
Coverage5,000 sq ft
WiFi TechnologyTri-band
Router: 4GB Flash and 512MB RAM
Satellites: 256MB Flash and 512MB RAM each
Seem very similar.
http://netgear.com/orbi
How big is your home sq ft?
I would try the 40 kit first.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RBRE960(v.85) and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 4
rvilata
Re: rbk40 vs rbk20
Thanks a lot.
Yes I believe they are very similar.  My home is less than 4000 sq ft, two floors.  So both systems fits.
The only thing that bothers me is Netgear have two products on portfolio for the same coverage.............
Message 3 of 4
Guru
Re: rbk40 vs rbk20
Ya seems like there really trying to squeeze out different products.
I have the RB40 system in my 5000 sqft place. Awesome system.
Let us know what you decide.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 11072 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
