- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
rbk50 new installation operating ok but does not allow me to login to admin
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just installed my new rbk50 ans satelite and all my devices have connected ok, but I can't login to the admin. It says incorrect password. Then when I try to reset it on your system it tells me incorrect security answers. I need hepl now!!!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
My issue with not being able to login to my new Orbi RBK50 admin was resolved. It required a Technician Reset. Since I had created the original password and security questions on an Apple 5 phone, it was probably a miss type on the tiny keyboard. Future management will be on an Ipad or PC. Thank You
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: rbk50 new installation operating ok but does not allow me to login to admin
What are you using as username/pass? I believe the default is: admin/password both lowercase, be sure your caplock is not on etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
dowb load the latest firmware, factory reset the orbi system and manually install the latest firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
