Orbi WiFi 7 RBE973
Reply
rbr50, rbs50y, rbw30 firmware service unreachable
CR-sound
My rbr50 and rbs50 units are at firmware 2.3.1.48. My rbw30 is at 2.3.0.4 with the note "service unreachable".  RBS50y is at 2.3.0.28 with the note "update failed".  Help with understanding/resolving the situation would be appreciated.  Thanks!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Guru
Re: rbr50, rbs50y, rbw30 firmware service unreachable
What is the Mfr and model# of the ISP modem the Orbi is connected too?
Manually download and use a PC to update the RBSY:
https://www.netgear.com/support/product/RBS50Y.aspx#download
The RBW is at it's current available version:
https://www.netgear.com/support/product/RBW30.aspx#download
Message 2 of 3
Blanca_O
NETGEAR Moderator
Hi @CR-sound
Were you able to update the firmware?
Blanca
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1190 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
