Reply
Highlighted
rbr50 rebooting FW 2.3.5.0
Not sure what is going on, but cannot keep connected for longer than about 30 minutes and then the orbi reboots or something.
I have performed a factory reset.
It is connected directly to my fiber conection and there is nothing in between..
Thoughts?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 11
Highlighted
Guru
Re: rbr50 rebooting FW 2.3.5.0
What Firmware is currently loaded? Please confirm version...
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 11
Highlighted
Sensei
If this Orbi was purchased within the last 90 days, it comes with "complimentary support" where you can talk to a Netgear person on the phone.
If it is more than 90 days old, did it EVER work correctly?
Just as a favor, could you please use the Orbe web interface, navigate to the Advanced Tab, and click on the "Connection Status" under Internet Port.  What do you see for:
  • Lease Obtained
  • Lease Expires
Thanks
I love my Orbi.
Message 3 of 11
Highlighted
I put the version in the title of the issue.
I am not sure about the
I have tried 1,6,11.
Distance between satellites is less than 30', but not turned on right now.
I am just using the router for now, and no satellites.
Hardware Version   RBR50
Firmware Version   V2.3.5.30
GUI Language Version   V1.0.0.360
Operation Mode   Router
What would cause the reboot?
Walter
Message 4 of 11
Highlighted
It has worked awesome for over a year, but just moved into a new home (both have fiber).
Lease Obtained0 Days, 23 Hours, 0 Minutes
Lease Expires
0 Days, 21 Hours, 22 Minutes
Message 5 of 11
Highlighted
Sensei
Thanks for the quick response.  Well... that shoots my theory all to hell.  A 1 day DHCP lease is pretty much "standard".
Can you describe more about what happens and when it happens?
I love my Orbi.
Message 6 of 11
Highlighted
it is typically about every 30 minutes, the WiFi  just drops.
then takes a minute or two to reboot.
The SSID disappears...strange...
Message 7 of 11
Highlighted
Guru
What devices do you have connected to the system? Wired and wireless?
 Any closer can be problematic...when you go to turn the RBS back on.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 8 of 11
Highlighted
 none of this works.   what is wrong with this firmware?
Message 9 of 11
Highlighted
Mine is running smoothly. 2 satellites on daisy chain config. Same firmware same router model, maybe yours is defective? I've only had mine for about 5 days though, however, no drops so far and near constant max speeds. I'm pretty impressed with the speed but less impressed with the coverage.
Message 10 of 11
Highlighted
Guru
Please give feedback to the questions presented so we can get a better idea of whats going on.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 609 views
  • 0 kudos
  • 4 in conversation
Announcements
