- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
rbr50 , want to add another satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an ORBI RBR50 setup. Works great in the house. Will reach in the garage a few feet near the window. I have an outlet right next to the window. What can I add in the garage, that will give me full coverage in my garage, that will work with the RBR50 setup that I currently have. Garage usage is mostly listening to spotify and occasionally looking parts up on the net.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: rbr50 , want to add another satellite
Every Orbi satellite will connect to your existing Orbi system, and any Orbi satellite will function in and certainly cover a two car garage as long as it can make a connection to the Orbi that is closest to it in the house. That is the key. If a smart phone or tablet can connect to the house system from any point inside the garage on a 5G channel, you are "good to go."
The "proof" is when you sync a new satellite (inside, in the same room with the Orbi router so you can watch what happens and look at the Orbi web interface all at once), then move it to the garage and see that ring light on the top turn BLUE for two minutes.
