Discussion stats
  • 3 replies
  • 140 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
rbw30 won't connect to router and I can't manually update firmware
My Orbi Wall Plug Satellite RBW30 was not showing up as being connected to my router (RBR40).  I tried syncing it, but that didn't work, so then ended up deleting it from my account on the website to see if that would start fresh to connect it.... but it didn't.  Now I can't manually update the firmware as I found instructions to do, because it isn't showing up in my account since I deleted it.  Is there a way to connect it back to my account with the ip or mac address or something so that I can manually update the firmware?
Model: RBW30|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 4
Highlighted
Guru
Re: rbw30 won't connect to router and I can't manually update firmware
What happens if you disable WiFi security mode on the RBR temporarily. Then try to add the RBW to the RBR while in the same room as the RBR. Does it connect then long enough to update FW on the RBW?  Use the sync button on the RBR first then press the button on the RBW. You might factory rest the RBW first, then try to add it.
If this fails, re-enabled wifi security on the RBR and contact NG support.
My Setup (Cable 900Mbps/50Mbps)>CAX80>Orbi RBK50 v2.5.1.16(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 4
Highlighted
thank you for your advice.  I was optimistic for it to work, but unfortunately it still won't connect.  I will try to connect to netgear support.
Message 3 of 4
Highlighted
Guru
Ok. Thanks for letting us know. Hope they can get you going.
Message 4 of 4
