- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
region change on RBK23
- Mark as New
- Bookmark
- Subscribe
- Permalink
bought a new Orbi RBK23 with RBR20 and RBS20, will move to Germany, can I change the region to Europe? maybe via telnet? found a method used on RBK53, but not sure if it works also on RBK23. did some one test this? thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: region change on RBK23
Once you log in to the RBRs web page, you should see a drop down menu that says AUTO under the log out button. Select this drop down and you can select the country available in the list.
@bearyoung wrote:bought a new Orbi RBK23 with RBR20 and RBS20, will move to Germany, can I change the region to Europe? maybe via telnet? found a method used on RBK53, but not sure if it works also on RBK23. did some one test this? thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What browser are you using? Try a different browser?
I looked at mine in Opera. It's selectable.
Might need a factory reset once you get into country and then setup from there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What you descibe is the GUI language, not the WiFi regional setting, lol.
