phat_tony's avatar
phat_tony
router dropping internet connection every night
Every evening a few minutes before midnight we lose internet connection. We can still access the network and router. There is no mention of internet loss in the logs.  RFV 2.3.5.30
  • Retired_Member's avatar
    Retired_Member
    RFV 2.3.5.30 has known problems.
    You may want to try an backstep your FW.  How did you receive RFV 2.3.5.30?
    • phat_tony's avatar
      phat_tony
      I have only just updated to it from the previous version the number for which i cant remember. tonight we will see if the problem continues.
        Retired_Member
        Why?
  • FURRYe38's avatar
    Happens for both LAN and wireless connections?
    Can you still access the RBRs web page when this happens?
    Has a Factory reset and setup from scratch been performed since last update? Something that maybe needed if you see this again...
