- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
school and work laptops will not connect with new orbi rbr40 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi! I am a tech novice so any advice is greatly appreciated. I installed an Orbi RBR40 router last Sunday and added several devices. The installation and connectivity for the various devices worked without issue. Tonight, I've attempted to connect my daughter's school laptop and my work laptop to the the network. Both of these devices connected without issue to the prior router network. Each time I attempt to connect on each device (Surface Pro and HP Elite Book 840), I receive a message from Windows Network Diagnostics that there is a problem with the wireless adapter or access point. I've followed the instructions to run the diagnostics then shut off and restart the computer to no avail. Any thoughts on how to fix this? Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: school and work laptops will not connect with new orbi rbr40 router
Did you name the SSID the same as the old router? if so you may need to go in the wireless settings of the laptops and remove the network and try to reconnect them.
DarrenM
