- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
slow WiFi speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
slow WiFi speeds
I even bought a second sattelite to improve but it’s still the same . I feel kind of helpless as my free support-time is over now.
Who has the same experience and does have an idea or solution?!
And the interruption of the connection in iOS is still a problem, even with the newest firmware...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: slow WiFi speeds
You will need a WiFi device with 5 GHz and at least 802.11n to get 100 Mbps over WiFi. What are you testing with? What speed do you get with a wired device plugged into the router, with WiFi OFF on the device?
- Mark as New
- Bookmark
- Subscribe
- Permalink
A Apple TV plugged to the Orbi-satellite with LAN gets at least 60/65 MBit...
Do you mean the Orbi-Router to plug something in?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was referring to plugging a laptop or desktop into the Orbi router and doing a speed test. The Apple TV result is good enough for now.
Your iPhone 7+ is a very capable WiFi client so that is not the problem. I get 470 Mbps with Orbi and my iPhone 7+.
The problem could be with your routers. Your Fritzbox is a router and so is Orbi. If you want to use Orbi with the Fritzbox you should turn OFF the WiFi radios in the Fritzbox so they do not interfere with Orbi. This is critical. You also need to switch Orbi to Access Point Mode, so that only the Fritzbox is doing the routing.
To setup Access Point mode: Log into the Orbi router with a web broswer, and go to Advanced, Advanced Setup, Router/AP Mode, and choose AP mode. Pay careful attention to the diagram showing how to wire the Orbi. You must connect Orbi's Internet port to a Fritzbox LAN port.
You might need to power cycle Orbi, the Fritzbox, and your devices after making this change.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m already in AP-mode and the Wi-Fi is turned off in the Fritzbox...
Actually is there any differences between the 4 LAN-Ports of the Fritzbox?
I hope you have some more advise...that would be great !
- Mark as New
- Bookmark
- Subscribe
- Permalink
