Orbi WiFi 7 RBE973
Reply
slow download / upload with ipv6 enabled
Mrgoodall
Star
My Equipment:
RBK50
Netgear CM1000
GB service with Xfinity
So, i recently upgraded to Xfinity GB service, was previously on 450MB tier. Noticed though that speedtests were roughly the same pre/post service upgrade (350-500MB). I hardwired into the CM1000 and was getting 978MB+ on speedtests, but Wifi stayed in the (350-500MB) range. I verified that Beamforming, MU-MIMO, and Fast Roaming were all on, and same speed. After some unsuccessful scrounging around the net, i decided to turn off IPV6 which was previously successfully set to "Auto Detect". After the config change, i ran another test, and low and behold:
Those speedtests are now in the 700-850 range on Wifi. Is this just my experience or is this a known issue?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 7
Guru
Re: slow download / upload with ipv6 enabled
What wireless device are you using for wireless speed testing?
@Christian_R
Message 2 of 7
Mrgoodall
Star
 Model Name: iMac
  Processor Name: Intel Core i7
  Processor Speed: 4 GHz
  Number of Processors: 1
  Total Number of Cores: 4
  L2 Cache (per Core): 256 KB
  L3 Cache: 8 MB
  Memory: 32 GB
and iphone 8Plus
Message 3 of 7
Guru
Does your ISP support IPv6 natively? If not, you can keep IPv6 disabled...
Message 4 of 7
Mrgoodall
Star
iphone 8p
iMac
Message 5 of 7
Mrgoodall
Star
yes
Message 6 of 7
Guru
Interesting find. I would presume it's not an issue if it helps wireless speeds.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1793 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
