Orbi WiFi 7 RBE973
Reply
switching requirements for ethernet backhaul
superbovine
Hello,
I have 2 satellites (RBS50) and I like to setup an ethernet backhaul to RBR50.
When I connected the satellite directly to the same switch as RBR50, it establishes and ethernet connection. However, once I moved the satellite to a different room on a different connect switch it does not work. I believe there are 3 switches between the satellite and RBR50.
Is this supported? Is any specific specification requirements with the switches?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only), RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 4
Accepted Solutions
Guru
Re: switching requirements for ethernet backhaul
What FW is currently loaded?
What is the Mfr and model# of the ethernet switch if one is in the configuration. Non managed switches are preferred and with out any GREEN ethernet features. If you have a Managed swtich, disable all IGMP protocols on these switches.
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1553749/highlight/true#M30673
https://community.netgear.com/t5/Orbi/Using-Router-Configured-as-Access-Point-Cannot-see-Satellites-...
https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-with-Managed-Switches/m-p/1613897#M3812...
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.  So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275...
Message 2 of 4
All Replies
Guru
Message 2 of 4
superbovine
I had green feature switch. I removed and replaced with a regular switch. Everything works fine now.
Message 3 of 4
Guru
Thank you for letting us know about the difference in switches. Glad it's working now. Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3221 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
