Modeck
Jan 03, 2021Aspirant
turn off 5gh on my cm1000
My smart plugs will not connect to my cm1000. How can I turn off the 5gh?
You're in luck!
The CM1000 is a modem only device. It doesn't have wifi.
so no need to worry about turning it off.
Or you can tell us which router you have so we can best help you :)
- ModeckAspirant
My smart plugs won't work on 5gh it seems. I have the google nest (3 of them ) set up.
