Orbi WiFi 7 RBE973
Reply
wall mount for RBS20
Getawaymike
Follower
Is there a wall mount for a RBS20 satellite?
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 2
CrimpOn
Guru
Re: wall mount for RBS20
Amazon sells an acrylic wall mount https://www.amazon.com/Netgear-BASSTOP-Acrylic-Bracket-NETGEAR/dp/B075N6JQND/ref=sr_1_5?keywords=rbs...
The advantage this has over mounting a tiny shelf is that anything pulling on the cord (cat? dog? child?) is not likely to drag it off.
There may be others as well.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 904 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
