Reply
weak signal
aiof1992
weak signal
hi
i have one Orbi router  and 3 satellite but the signal is week on my villa i move it around nut same thing no improvement i believe i cant add more satellites i wonder if i add range extender will help or other solution
Thank you
Model: CATRBR50-100NAS|Orbi Premium CAT5e Flat Ethernet Cable
Message 1 of 4
Guru
Re: weak signal
Which model Orbi do you have?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 4
aiof1992
Re: weak signal
RBS50
2.1.4.16_1.1.23
Do not know
Router
+- 25 sq ft
less than 20 ft
Model: A6200|802.11ac Dual Band WiFi USB Adapter
Message 3 of 4
Guru
Re: weak signal
RBS50
2.1.4.16_1.1.23 There is newer version of FW available. You may want to update the RBS then RBR. v30 is the most current version
Do not know Please find out this information. Would be helpful.
Router
+- 25 sq ft 2500sq ft?
less than 20 ft 20 feet is too close between the RBR and RBS. Place the RBS out at 30 feet to start.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2438 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
