- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
wifi upload speed, ping value are strange
- Mark as New
- Bookmark
- Subscribe
- Permalink
I use R8000 before, the download speed and upload speed is normal 150Mb/150Mb(down/up) ping time under 5ms, but i change to orbi, i use my new ipad, iphone 6s and iphone 6 plus to test the speed, the download speed is 150Mb, but the upload speed sometime is 150, after 2 second, i test again, it is 20, 25 or sometime it become 150 again...... and i also notice that the ping time is 5ms, 45ms, 54ms, different in every test.......... but i use my computer via the lan port to test it, it is always 150/150, ping time under 5ms, i use facetime smoothly before but now i even can not use the facetime to talk to my friend, i think it is the bug of the wifi , any idea ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: wifi upload speed is strange
Hello godseesad
Make sure you have the latest firmware you also may want to change the wireless channels see if that improves your wireless connection.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
different versions of firmware, same result !
different channels, same result !
enable or disable MU-MIMO, same result !
enable or disable BEAMFORMING, same result !
factory reset n times, same result !
I spend 4XX to buy this one, very disappointed !!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello godseesad
Have you gone straight to the modem and ran some tests to make sure the modem if giving the correct upload?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only the IOS devices have this problem ! my laptop and desktop is normal !
- Mark as New
- Bookmark
- Subscribe
- Permalink
last thing you could try is back up your routers config and then factory reset the unit as the last firmware was a huge update and then test your IOS devices before loading your config back on the unit.
DarrenM
