- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
wireless security system issue with RBR40
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: wireless security system issue with RBR40
Is the Orbi system operating in Router or AP mode?
Are the security cameras wireless or wired to the NVR or Orbi?
How is the NVR connected to the Orbi?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Contact the camera Mfr for additional help and information on using there product with home class MESH Routers.
