Orbi WiFi 7 RBE973
Reply
2nd GS308 managed switch does not get an IP
andrevanm
Hello,
Forgive me if I ask something very obvious or something impossible.
This is my situation. I bought a second GS308T switch to extend my network. The first one connected to my router already has an IP assigned via DHCP, bu the second (new) one who is connected to the first does not get an IP. Why is that? And how can I solve that?
Model: GS308T|NETGEAR® S350 Series 8-Port Gigabit Ethernet Smart Managed Pro Switch
Message 1 of 15
Accepted Solutions
schumaku
Guru
Re: 2nd GS308T managed switch does not get an IP
Exchanged to new devices, or A-B to B-A?
Ensure both switches are operating on the current firmware -> GS308T | Smart Managed Pro Switch | NETGEAR Support - as of writing it's 1.0.1.2 (don't be confused with 1.0.0.12).
Do a factory reset if the status is potentially unclear or undefined.
Perform a Cable Test on both switches...
Message 9 of 15
All Replies
DaneA
NETGEAR Employee Retired
Re: 2nd GS308 managed switch does not get an IP
@andrevanm,
Welcome to the community! 🙂
Is the 2nd GS308T directly connected to the 1st GS308T?  If yes, what is the color/behavior of the port LED lights connecting the 2nd GS308T and 1st GS308T?
What is the current firmware version of the 1st and 2nd GS308T switches?
Are there VLANs configured on both 1st and 2nd GS308T switches?
DaneA
NETGEAR Community Team
Message 2 of 15
andrevanm
Thanks for  your reply DaneA. I appreciate it very much.
Concerning your questions:
>Yes
>1st GS308T: once in a while blinking orange shortly
>2nd GS308T: green and blinking
>1st GS308T: I think same as 2nd switch as it is brand new.
>2nd GS308T: Boot version: 1.0.0.1  Software version: 1.0.0.12
>No
Message 3 of 15
schumaku
Guru
Something wrong there.
Tried a different cable?
Tried a different port for the link on either of the two switches?
Message 4 of 15
andrevanm
Thanks Schumaku for your suggestion.
I don't think it is the cables as when I connect the cable to the second switch (remove it from the switch) and connect it to my computer, I do have proper connection. I also tried different ports but to no avail.
Message 5 of 15
schumaku
Guru
So test different port on the other switch.
Message 6 of 15
andrevanm
I need to make a correction. The led on the 2nd switch is once in a while orange, not green.
Message 7 of 15
andrevanm
I did but to no avail. Actually I exchanged both switches.
Message 8 of 15
schumaku
Guru
Message 9 of 15
andrevanm
A-B to B-A
Thanks for the advice guru Schumako .
Will try that.
Message 10 of 15
schumaku
Guru
Curious - what made it work as expected - current firmware?
Message 11 of 15
andrevanm
First of all, big thank you for your great help.
I did all the suggestions you gave me. First, reset the switches. Secondly upgraded the firmware. Then I noticed that issue was still there. So I tried another cable between switch1 and switch2, that did the trick. To me not very obvious as the cable was working when it was connected directly to my laptop.
Again your help was greatly appreciated.
Message 12 of 15
YeZ
NETGEAR Expert
NETGEAR Expert
Glad to hear that.
Can you tell us what is the difference between the working cable and the non-working one?
Thank you.
Message 13 of 15
andrevanm
Good question.
To be honest: I do not know exactly. The cable was working for the laptop but not for the switch. But in order to try my chances, I replaced the connector on both sides and this did the trick.
Message 14 of 15
YeZ
NETGEAR Expert
NETGEAR Expert
No problem, thank you for the information.
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 2821 views
  • 0 kudos
  • 4 in conversation
Announcements
