- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can GS108E, WN203, and FVS318N support a VLAN 0?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I configured a Netgear FVS318N router, Netgear WN203 access point, and Netgear GS108E switch, all VLAN aware, to support two VLANS, VLAN 1 and VLAN 2. When I got to church to install the equipment all went well until I realized they have an airconditioning software controlled system on subnet 0. So, I had to put the old router back into service, as it is on subnet 0. I plan to get with the company that supports the software that serves that equipment to see if they can change the subnet to 1. But, I was just wondering if anyone here knows if there is a way to setup the router, access point, and switch to support subnet 0?
Thanks for any help!
DonD
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DonD,
Have you tried to change the IP settings on your FVS318N to use subnet zero? If yes, is there an error message that appears?
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DonD,
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can GS108E, WN203, and FVS318N support a VLAN 0?
Hi DaneA,
Following on your suggestion, I changed the IP address of the router for the Default VLAN to subnet "0" and found it worked. Now, any use of VLAN 1 results in a subnet of "0". So, I'll setup "FUMC_Staff" to run on subnet "0" (VLAN ID 1), and "FUMC_Guest" to run on subnet "1" (VLAN ID 2). Guess my problem was I was thinking "VLAN ID" corresponded directly to the subnet. Thanks again for your help, DaneA!
Don
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DonD,
You're welcome again! 🙂 I am happy to know that its working. 🙂
Don't hesitate to post your future concerns here in the community.
Cheers,
DaneA
