Orbi WiFi 7 RBE973
Reply
Can't get GS110TP to work as simple as GS105E
APDK66
For my work I have to check services going over utp links in different vlans. I used a GS105E with its mirror function. I can connect the GS105E without any vlan configuration and all traffic of dozens of vlans passes transparent over the switch.
Now I have to do the same over fiber optics and got a GS110TP for that but can't get it to work as simple as before with the GS105E.
Now it looks like that I have to configure a lot of vlans and that the GS110TP is restricted to 64 vlans.
Does someone know how to do it similar on the GS110TP as on the GS105E?
Message 1 of 11
Accepted Solutions
APDK66
Re: Can't get GS110TP to work as simple as GS105E
So I understand I can't use this switch for what I want. I need to check uplinks containing 250+ vlans.
Besides the different configuration effort each time it has a limit of 64 vlans.
I have to look for another solution.
Message 10 of 11
All Replies
DaneA
NETGEAR Employee Retired
Hi APDK66,
Kindly answer the questions below:
a. What is the current firmware version of the GS110TP?
b. Have tried to reboot the GS110TP?
c. Have you tried to perform a factory reset on the GS110TP?
I look forward to your response.  Welcome to the community! Smiley Happy
DaneA
NETGEAR Community Team
Message 2 of 11
APDK66
Hi DaneA,
thanks for your answer,
The switch has firmware version 5.4.2.19. I did reset and do a factory reset.
The current situation under test:
- factory default setting
- link with vlan 4, 6 and 7 connected to port 1 & 2 of the switch.
no traffic passes the switch.
Arjan
Message 3 of 11
DaneA
Hi APDK66,
Here are my follow-up questions below:
a. Are ports 1 and 2 of the GS110TP connected to another switch?
b. What are the port members of VLANs 4, 6 and 7?
Kindly post a screenshot of your detailed network setup.
DaneA
Message 4 of 11
APDK66
Message 5 of 11
APDK66
The trunk carries vlan 4,6 and 7 for different services. Connected with the GS105E it works with default config. Connected with GS110TP with default confifig it doesn't work.
Message 6 of 11
DaneA
Hi @APDK66,
Kindly set ports 1 and 2 as tagged (T) ports.  What is the behavior and the LED color of ports 1 and 2?
You may use other ports of the GS110TP as trunk ports to isolate the problem.  Just make sure to set it as tagged (T) ports.
DaneA
Message 7 of 11
APDK66
I did set the ports to trunk on vlan1 the default vlan. That is the only place to set tagged/untagged mode.
Only when I define vlan 4,6 and 7 in the switch it is working when I make the tagged ports a member of those vlans. Without defining vlans the switch just won't forward any frame like the GS105E only untagged frames.
The port connected to the CPE/router is blinking while it sends PADI frames to setup a PPPoE in vlan4. The led of the port connected to the FiberNt is burning green but not blinking.
I think when you want to use this switch you must always define (and  know) all the vlans on the trunk and the number must not exceed the 64.
Message 8 of 11
DaneA
Hi @APDK66,
I would agree that proper VLAN configuration is required on the GS110TP.  I conclude that not all switches would work instantly with the given default configuration like the GS105E.
DaneA
Message 9 of 11
APDK66
Message 10 of 11
DaneA
Hi APDK66,
You may want to check and consider the ProSafe Gigabit PoE/PoE+ Smart Managed Switches that supports 256 VLANs on this link below:
http://www.downloads.netgear.com/files/GDC/datasheet/en/GS516TP-GS728TP-GS728TPP-GS752TP.pdf
DaneA
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 6396 views
  • 0 kudos
  • 2 in conversation
Announcements
